Amp Aerial Connection
    I've been having a problem with my Amps cutting out recently and not working and for the life of me i couldn't work out why.
    After a hour of reconnecting all wires i attacked the head unit. My remote on wire is bi wired to amplified aerial connection then to the remote on - on the head unit.
    When i disconnected the Amplified aeril wire, everything sprang into life!!!
    Now i'm totally baffled as this configuration has been working for 3 months and it don't work now unless the amplified aerial is disconnected.
    Any ideas?
    In the meantime i'm going to try a different 12v source for the aerial maybe of the switches, depends!
  • Stick Insect
    • Dec 2003
    • 2338
    Hi Jamo, check for earth faults, the cable could have been damaged. The best thing to do is to use a small relay and power the ariel from that.
    HTH
    David
