CD Sound Problem
  • ianmt
    • 130
    CD Sound Problem
    Does anyone have any ideas? The sound has stopped from by Blaupunkt boot fitted CD Changer. At first it stopped intermittently, and I put this down to the dampness and leaking boot syndrome, but now, with a dry boot, the sound has stopped completely. The CD changer is working and changes discs, as I can hear this from inside the car, also the display on the dashboard indicates the chamges. It will only "try" and play the first track of each disc, no sound occurs, then it changes to the next disc, and same thing happens.
    The sound on the radio is fine.
    What should I check? Any help would be appreciated.
    Thanks
    Ian
    '91 3B Coupe
    Sounds like the laser on the changer to me mate, if you've got a cd cleaner i'd try that.
    Cant think of a quick fix if it is.
    Could also be the cable but if your hearing it skip disks then it's most likely laser allignment or laser has gone.
    • ianmt
      • 130
      Thanks Jamo, I'll try disc cleaner first.
      Ian
      '91 3B Coupe
      • ianmt
        • 130
        Jamo
        I tried cleaner, no luck, so have removed unit and sent it away for checking. Am now told "Beyond economical repair".
        Question is, will I have to replace dash unit and wiring too to connect a new CD changer? Anyone got any further advice?
        Thanks
        Ian
        '91 3B Coupe
          Not if you get the same changer or one with in the same model range from Blaupunkt mate.
          Check ebay.
          • Pete_RS2
            • 800
            It depends what head unit you have & what changer you buy. See the Blaupunkt website - there's a compatibility chart available there.
            Now RS2'less
            '99 VW Passat VR5 Sport
            • ianmt
              • 130
              Thanks Jamo/Peter
              I am waiting to hear from Blaupunkt as to compatability.
              Peter, do you have an address for Blaupunkt chart? I could not find on search. Unit was original with car, 1991, so maybe not suitable for new CD Changers?
              Regards
              Ian
              '91 3B Coupe
                Check the car configurator
                • horvathg
                  • Dec 2003
                  • 556
                  Originally posted by Jamo
                  http://www.blaupunkt.co.uk/index.asp
                  What exactly is your headunit? A lot of manufacturer uses the same hardware with their own brandname on it. Some might suit yours too.
                  Gabor
                  96 ABY coupe full except sunroof. With Porsche big red brakes, remapped ECU, xenon lights, RS2 MAF
                  • horvathg
                    • Dec 2003
                    • 556
                    http://search.ebay.de/blaupunkt-wech...wordredirectZ0 there are only 162 items matching your wish. And from 5 euros....
                    Gabor
