RNS-E in Audi RS2
  • Smiley
    • Jun 2005
    • 329
    OK, took quick measures:
    21,2cm outer width of the bracket
    21,7cm metal front parts of the RNS-E
    But - if I assume cutting the right away just at the most right buttons of the RNS-E
    I have some frame avaiable at the left of the display. I think its the way skaala has done it.
    I don't have the very small torx an cross-screwdrivers to dismount the bezel to have a look whats behind...
    Anyone btdt on a RNS-E ??
    '93 Audi S2 Avant panthero black, 412.000km
    '94 Audi S4 C4 Avant 303Tkm, KW, Brembos, BN-Pipes, Bose, S6 front (sold)
    '93 Audi S4 C4 Avant, 260Tkm
    '88 Audi 100 Avant turbo 44Q
    '84 Audi 80 quattro tornado red
    • Smiley
      • Jun 2005
      • 329
      Having a very close look at skaalas pics I tend to see some space right of the buttons,
      may be its just a press fit?
        Smiley got any details on the CAN-Adapter?
        • Smiley
          • Jun 2005
          • 329
          Accidently found a box with 21,7x22cm width..
          It IS a press fit. The inner walls of where this all goes are weak - just like the dashboard all round.
          @Jamo, mine is just an ISO->RNSE plug spaghetti adaptor without any special circuit like this:
          http://cgi.ebay.de/Plug-Play-Adapter...item483b138f71
          we will see..
          Now I'm going to reduce the width of the bezel, at first some try cuts on the outer edge to find the right tool..
          • Smiley
            • Jun 2005
            • 329
            Success!
            With a small bow saw i cutted along the inner plastic that surronds the metal very close, using it a a lead/guidance.
            Then i used sandpaper to round the edges - easy job, just be patient.
            This got me a total width of around 21,7cm as expected,
            and as suspected it IS a press fit you notice some little space left and right of the buttons.. is ok for me.
            As you see its a test fit, the GPS cable is hanging around.. At the moment I don't know what will go into the gap below, the A/C controller will move to the aux gauges, this will be step 3. Step 2 is getting radio, nav and GALA running..
              What's the width of the outside of RNS-E unit now modified to fit in the S2 dash?
              • Smiley
                • Jun 2005
                • 329
                The overall width of the bezel which has to fit in the dashboard is 21,7cm, as mentioned :-)
                You could get to 21,5 with more patience than i had this morning - maybe I will fine-tune it again with sand paper..
                Now i just need the PIN - got the wrong one
                In the meantime I will investigate what should me connected to the three connectors at the back of the unit, that all look like GPS ones to me
                • Acidburn
                  • 13459
                  looking very nice, something I looked into doing a while ago
                  • Smiley
                    • Jun 2005
                    • 329
                    Up to this point, easy job. What i definitely have to do is integrate some supportive bracket in there - at the moment the navi is just pressed between the 'walls'.
                    The fun begins with the cables - it seems i have only the ignition+, not battery; and there are no ground connections in the speaker ISO Plug of the adaptor, GALA and CAN(?) will be a separate topic..
                      • A80Avant
                        • Sep 2005
                        • 10873
                        • Country: Greece
                        #26
                        that does look nice. I have a custom made case to move the buttons from the main dash, next to the handbrake. I have never got around doing it though. I would also go for car pc instead but.. enough with the upgrades!! haha
                        • JTK
                          • Aug 2007
                          • 143
                          Looks really nice, but what about a/c?
                          • Smiley
                            • Jun 2005
                            • 329
                            a/c will go down, removing the useless ashtray should give the required space for a/c and the aux gauges, have seen it somewhere..
                              Has anyone got any technical details on the actual RNS-E units
                              • Smiley
                                • Jun 2005
                                • 329
                                The newest one seems to be in the Q5 called MMI 3G...
