Right so yesterday had the whole combo of trip clock and player not working due to fuse blown.
So redid the settings on the headunit went away changed over my rear demist button left the car.
Went for a quick test run and the headunit not powering up
So checked the fuse knowing its fine as the trip and clock are displaying info.
I do know the wiring behind the headunit is messed up. Previous owner.
I'm thinking the switch power is feed off the back of said switch I changed. Maybe when pulling it through has knocked it out.
Will check this after work. Any other thoughts??
Chris
Chris
