Just installed a new head unit the hard way as the wiring loom was wired into a crappy aftermarket stereo. Can anybody help me identify the correct colour wires for the rear speakers and identify the ones left over please?
So far I’ve worked out,
(Power)
Red/Blue : + power (non switched)
Brown : - earth
Grey/Blue : Instrument Illumination
Two White : Aerial? On the old head unit it was connected to the remote aerial signal, is this correct? Is this the power feed for the antenna amp (on roof)
I also can’t figure out what the following are for on the same wiring loom,
White/Blue : ?
Brown/Grey : ?
(Speakers)
I found the two fronts, Large Green & Green / Black for each side.
For the rear the old stereo was wired as below except only the tweeter works on the right hand side.
Blue/Green : RL+
Brown/Red : RL-
Red/Green : RR+
Brown/Black: RR-
On the same wiring loom there is also the following disconnected,
Red/Yellow : ?
Grey/Red : ?
Red/Brown: ?
Can somebody please explain the rear speakers, AFAIK there are the two each side of the rear seat and two tweeters each side of the back shelf. Are these amplified speakers, if so how do I wire them? And what are the five unknown wires left over for
Thanks,
Mark.
(Power)
Brown : - earth
White/Blue : ?
Brown/Grey : ?
(Speakers)
Blue/Green : RL+
Brown/Red : RL-
Red/Green : RR+
Brown/Black: RR-
Red/Yellow : ?
Grey/Red : ?
Red/Brown: ?
Thanks,
Mark.
