Radio aerial's Kaput- Poor reception
  • raymor
    • Sep 2003
    • 597
    My Radio aerial's kaput on my Avant... the implication from the local sound shop is that I need it renewed completely.
    I suspect it's the integral amplifier, is that part of the aeriel itself or is it hiding somewhere else.
    Has anyone else had problems with it... and what was you solution ( there's only so many CD's you can listen to.... )
    cheers
    Raymond
    1997 A6 (C4)Q TDi http://forums.tdiclub.com/showthread.php?t=291269 - Sold
    1987 CQ85RS
    1994 S2 Avant- Gone
    1991 V8 -Gone, but lives on in the TDi and CQ
    Fintray Hillclimb - 33.20s
    Doune Hillclimb - 55.02s
    Forrestburn Hillclimb - 52.61
  • jameswkr
    • 538
    I'm told its a common VAG problem. The amp is in the base of the (beesting) aerial. Keep meaning to get it done myself but I like the sound of the engine! Sad I know..........
    • Pete_RS2
      • 800
      I had to replace the amplifier base on mine last year which cost about £60 from Audi. Unfortunately I learnt a few weeks later that some Vauxhall bases will work & have exactly the same fixing at a fraction of that cost. I can get a part number if you want ? If you need to replace the bee-sting mast you can get them from Maplin for about £3.
      hth.
      Now RS2'less
      '99 VW Passat VR5 Sport
      • Alistair C
        • 693
        just make sure the amplifier is still getting power.... If someone changed the head unit it is quite possible they forgot to rewire the aeriel amplifier back in.
        I think it is a plain white wire on the radio loom ...... I spend 6 months in my old coupe with cr*p reception because I did just that!
        • raymor
          • Sep 2003
          • 597
          I got the installer to check that the DC feed was present and it checked out ok.
          Peter, if you've got the part number to hand, that would save me a bit of rooting around. Is that the Audi part number or the Vauxhall equivalent?
          1987 CQ85RS
          1994 S2 Avant- Gone
          • Pete_RS2
            • 800
            Raymond,
            The Vauxhall part number is 90389799 which costs £18.66 + VAT. The roof mounting is the same. You will just need to put a different terminal on to match the Audi one. Should save you about £40.
            Now RS2'less
            • raymor
              • Sep 2003
              • 597
              Thanks Peter, I'll order it from my local garage.
              Avants..... you just can't beat the grin when you leave the 'sporty' boys behind
              1987 CQ85RS
              1994 S2 Avant- Gone
              • dan_b
                • Sep 2003
                • 3670
                I've got similar poor radio eception on my system, which is annoying because it was fine with my head unit when it was in its previous car, and the system that was in there also had fine reception - think something went hookie during the swap over.
                • scouser_75
                  • 306
                  I also used to have very bad reception on my radio.
                  I have a Kenwood face off, and when my mate had a look at it he sussed that it was the wiring at the back which was a little suspect. So a bit of tampering there and everything seemed to be OK. Untill recentely, when the reception has wavered again
                  Dan B, maybe try checking all your wires again. Also, if you have a face off, sometimes the connection between the face and the head unit goes off key a little, so checking that may be worth while too.
                  Alps
                  • dan_b
                    • Sep 2003
                    • 3670
                    I think it may well be a dodgy install - I didn't have the time to do it myself so paid someone else to do it. First time I got in the car after that I instantly recognised the old "out of phase" sound coming from the fronts - the prat had wired it up wrong!
                    I've got a Pioneer face off jobbie which I considered to have had a good tuner. I'll get it out and have a look, see if anything else is screwed. The bee-sting is quite new on the car.
                    • GlynRS2
                      • Dec 2003
                      • 307
                      There are a couple of things to note when getting poor reception with a VAG bee-sting aerial:
                      1) If you still have the original base unit for the aerial on the roof, make sure that there is power connected to the wire that runs with the aerial cable behind the head unit (this sometimes gets left off when the head unit is changed) it usually fairly easy to identify as it is bound together with the aerial co-ax cable.
                      2) If the aerial base unit on the roof has been changed at sometime for a later one, the power feed to the amplifier is different in that it is sent up the aerial co-ax cable itself and not in a seperate wire ( with this you can't find anything to attach the seperate wire to at the base unit). This is often done as the later type base unit as fitted to all later Golfs, Polos etc is much cheaper. You then need a special adaptor to fit behind the head unit, see:
                      Find information, resources and relevant links for incarexpress.co.uk. This domain may be for sale.
                      Hopefully, this should help you get your radio reception back.
                      Glyn
                      Ex-Polar Silver RS2
                      Sprint Blue RS4 - new toy :mischeif:
                      • cochyn92
                        • 38
                        • Home: Wales Current: Fujairah
                        Hi.
                        (Hope you S2 honchos don't mind a mere 20V'er posting here )
                        Had the same problem, and ended up buying the amplified roof aerial from GSF for about £13. Trouble was the seal at the bottom was ****e - let in loads of water- no matter how tight the fixing nut was. I ended up butchering the new aerial for it's (non-rusty) circuit, soldered it into the old (water-tight) Fuba base and re-wired it with the proper connectors. I sealed-up the base-unit with Terostat V11 and stuck the whole refurbished lot back on the roof. Hey presto: 'New' Fuba aerial for 13 sovs and a bit of soldering.
                        • Stick Insect
                          • Dec 2003
                          • 2338
                          [QUOTE=cochyn92]Hi.
                          QUOTE]
                          All the best looking memers of the forum have Coupe Quattro 20V's
                          Welcome to the forum.
                          David
                          • cochyn92
                            • 38
                            Cheers mate.
                              Oooops think i might have done this, should the white wire be connected to the auto aerial on the stereo then?
