RS2 Blaupunkt help
  • alg
    • Apr 2004
    • 1160
    RS2 Blaupunkt help
    RS2 has original Blaupunkt canberra unit. Just back from some garage and I cannot get it to select CD option. Oh and I have checked the cassette is loaded in boot unit.
    I never had manual so just pressed various buttons until got CD and never used radio. Did not work this morning.
    The buttons that seem to be CD are labelled src , then there are the + - CD selection buttons and track selector which tunes radio in radio mode.
    Anyone know what combination or button to press is ? Or could the CD feed have been disconnected ?
    Battery would have been disconnected to replace ext temp module (failed to work needs pc board connection repairing err Doug can i borrow your solder kit !!). But no reason to remove radio as only other work was ax gauge bulb replacement.
    Alastair
    RS2
