S2 coupe roof aerial
  • S2 coupe roof aerial
    My car needs a replacement roof aerial. The original is a 45 degree type.
    These are now NLA. What have people used as a replacement? Does anyone have a picture of the aerial connector in the roof? How it is amplified etc? Heard a rumour that the mk4 golf item can be fitted, but I think it's a 60 or 76 degree aerial base
    Tom C - www.rcmr.co.uk
    Audi UR Quattro
    Audi 100 C3 2.0 5 cyl 115ps
    Audi B5 RS4 645ps 911nm
    I bought the one below because the original one was leaking water inside the car, the plastic gasket between the base and the body had deformed.
    The new one fitted in place no problem but the connection on the co-axial cable was different and it has no built in amp. The radio reception is no better than before.
    So........in short, I'm just glad water isn't getting in!
    http://www.ebay.co.uk/itm/2915591343...%3AMEBIDX%3AIT
      A Vauxhall Corsa B aerial base is a direct fit, the amplifier feed is slightly different but this is easily adaptable. The angle isn't quite right though, probably around 70 degrees which might bug you. Some people have used an inline amplifier which would probably be the best solution if you want to keep the correct angle.
      Worth checking that the current aerial is getting power as it might have inadvertently been cut. Just remove the roof light underneath the aerial and the wires are right there.
      Here's a Corsa one that I bought previously:
      http://www.ebay.co.uk/itm/1524528232...%3AMEBIDX%3AIT
        If its the same as the avant the Hirschmann DAB/FM ariel is a direct fit, Has amplifier and connectors are all the same for the FM with additional bonus if you change to a DAB head unit
        Paul
        1995 RS2 Nogaro
        1971 Lotus Elan Sprint
        1974 Lotus Elan+2S 130/5
          I am interested in this too, which will be done when my headlining is replaced. I thought I had seen a correct aftermarket one, but don't remember where. I would be interested in what others find.
          Cheers,
          Steve
          The Perfectionist
            think this about as close to oem... https://www.buycarparts.co.uk/beru/994026
            1992 3b S2 Coupe
              Paul
              so this one: https://www.amazon.co.uk/Hirschmann-.../dp/B00KX4KRRY
                That Hirschmann one looks way too steep, the Beru one linked appears much better, at least over the internet.
                  I bought one from eBay a few years back and it looks OE.
                  91 Modded 3B
                  14 A6 Avant Black Edition
                    A good find thanks for the link. Unfortunately got one of these today and it is being sent back. The quality is terrible, it feels light hollow and cheap, there is no seal so I can see a lot of water getting in, the wiring is completely different. With some modification it would probably work. An inline amplifier would probably be a much better bet, has anyone got any details of an inline amp that works?
                    A few photos:
                      where can i get just the Ariel screw in part?
                        A few photos:
                        That's the same one I got, it also went back, quality was terrible!!
                        http://www.s2forum.com/forum/showthread.php?t=76640
                        The cheap Ebay one is miles better
                          just the whip antenna? I think you can get them from ecp or gsf...
                          1992 3b S2 Coupe
                            Ive just put a hirschman one on the RS2, yes its a bit steeper but you would not notice unless parked next to another, superb quality and works well, can change with the headlining in place
                            Paul
                            1995 RS2 Nogaro
                            • #15
                              Paul
                              good to hear. have you been able to test it in a proper Scottish rain? That's when mine started to leak, the drizzle we have here is no problem for the seal
