I try this question here insted of at the bottom of another huge thread. I have the green top mounts in front on my S2 Coupé. I did not get through the annual car checkup, SBP, that we have here in sweden because they said the top mounts didn't "rotate" as easy as they should. The thing is that they have ony been on the car for like 1000km and are brand new. Anyways there wasn't much else to do then take it all apart and take a look at it. I replaced the grease in the top mounts and replace all nuts and put it all together. Still have the same problem but after some serious lobbying they accepted the car at the SBP. But they were not all to happy that it didn't rotate as easy as it should.
And now afterwards I have been thinking a bit. I now have the green top mounts and originally it is supposed to be the blue ones. Someone said to me that the green ones are a bit "taller" then the blue ones. So maybe the green ones touches the metalplate at top of the spring and therefor dosn't rotate as easy as it should. So I wonder if you guys with the green top mounts used a washer between the metalplate and the top mount? Any other theories? I hope my problem is understandable, I ain't the best at english. =)
When they told me that they wouldn't approve the car at the check up there was no money for the solid ones. But i will fix a group buy of the ones from qrsport to sweden in a month or two.
