Just wondered, are there any adjustments that can be made to the S2 steering rack?
I seem to be noticing that the steering feels very vague on the straight ahead at the moment, and it feels to me that you can turn the steering wheel a fair few degrees in either direction without that turning the car at all. The steering wheel is very light in that small amount, then you can feel it weight up and it turns. Once in the turn, it's fine. It's very odd and I don't know if I've described that very well, but at the moment it feels a little disconcerting - for example just going along the m-way at speed, you normally make only very small corrections, but it feels like you turn the wheel that little bit and nothing happens...
There seem to be a few groaning/creaking noises from the front suspension periodically, but that happens to all of us as we get older doesn't it!
Has something broken, worn out or just needs tightening/ adjusting?
last year I replaced my leaking servotronic rack with a normal one, so it's not the servotronic. I changed the top strut mounts earlier this year too, as well as putting on the RS2 FARB/ Whiteline RARB.
Any suggestions of where to start?
Does anyone know if there's an idiots guide anywhere for adjusting the steering damper? For an idiot
