used parts might be needed
  • Chris5044
    • Feb 2005
    • 1663
    i might have to look for some parts for my car......
    If i do.... im after front lefthand drive shaft, hub assembley and suspension strut complete....
    Anyone breaking a car? ... are these parts the same as a coupes?
    am desparately short of cash...
    dunno for sure if i need this..... has anyone got these tho?
    there was one being broken on ebay. a 3B, also worth trying all audi who should have bits like that
    • S2 Ant
      • 3682
      Why do you need all them parts?
      Have you crashed it?
      Ant
      2011 Kawasaki Z1000
      • Chris5044
        • Feb 2005
        • 1663
        its a long story..... going to mechanic tomorrow... but im getting a low deep "whomm"
        sound when i turn left... ive had it since i hit my front left wheel sideways off a kerb.... (i had to replace the wishbone and get alignment done)... the same sound was heard before wishbone was sorted)...
        been driving it hard round corners and the sound has returned louder since and now u can feel this "whomm" through the pedals... (the sound was always there when i turn left since knock - now its louder)
        sounds as if its like a rolling noise ... you hear (whomp whomp whomp (sound occurs every sec when turning)
        mechanic said it could be possibly drive shaft.. someone else reckoned wheel bearing .. getting it closely looked at tomorrow....
        my thoughts were to buy the whole area to eliminate the problem (suspension etc drive shaft)
        could be wheels? dunno u got any ideas? (was side impact on left of front wheel with full right lock on)(understeer)
        • S2 Ant
          • 3682
          Thats one hell of a bill you are looking at instead of just fixing the problem!!!
          I'd suspect wheel bearing first from that noise you describe, possibly even CV joint as its when you're turning.
          Ant
          2011 Kawasaki Z1000
          • Chris5044
            • Feb 2005
            • 1663
            is that easy enough to strip and repair... cause i was told that u cant simply strip the bearing?
            • S2 Ant
              • 3682
              It depends what you are comparing it to.... changing that whole side of the car will cost you a lot more in labour and parts than replacing a wheel bearing!
              It needs to be done by someone with a press, as thats how they are fitted, CV joints are a peace of cake.
              Exercise a bit of common sense here
              Ant
              2011 Kawasaki Z1000
              • volcano rs
                • Jun 2005
                • 2265
                take you hub off get it checked from a garage and if it is the wheel bearing get one from euro car parts and have it pressed in. has to be done with a press .if it dosen't solve your problem then it might be the cv joint .
                • Chris5044
                  • Feb 2005
                  • 1663
                  k dudes thx will let u know the outcome!!!
                  • Chris5044
                    • Feb 2005
                    • 1663
                    ok how much does someone want for
                    1x complete driveshaft (front left hand side as if sitting in car)
                    dont mind it being second hand .. so long as its not damaged and functions correctly
                    • S2 Ant
                      • 3682
                      Is that whats wrong with your car then?
                      Damaged the drive shaft?
                      Ant
                      2011 Kawasaki Z1000
