Needing help with Steering Pump Leak
  • Knight Rider S4
    • 3541
    Got back to my house tonight and caution light comes on and steering making a whoore of a noise.lucky for me i was just parking up.....Opened the bonnet and there is hydraulic fuild everywhere after cleaning it up the leak is coming from a cross shaped stud on top of the pump tried to tighten it up to see if that would help but only helped a little ..what i am needing to know if it is o ring seal below stud that has gone .......and if anybody here has ETKA Cat for the diagraim of pump which with a bit of luck should show me were the seals are situated
    Steve
    93 S2 Avant Parting
    91 URQ RR
    02 A4 tdi Avant
  • MidnightBlueS2
    • Jul 2005
    • 1653
    • Home: United States Current: Belgium
    Yup, there is an o-ring down there...
    Here's my thread on the subject. http://www.s2forum.com/forum/showthread.php?t=12591
    HTH,
    David
    Midnight Blue S2 - SOLD - 1993 S2 Avant
    • Knight Rider S4
      • 3541
      Cheers David
      I take it the steering pump will be the same on my S4 as it is on S2?
      Steve
      93 S2 Avant Parting
      91 URQ RR
      02 A4 tdi Avant
      • MidnightBlueS2
        • Jul 2005
        • 1653
        If you have a 2.2 liter turbo ABY engine, I would be surprised if there was a difference... But I'm no expert...
        • Knight Rider S4
          • 3541
          Just got ETKA CAT and seems the same...............what Hydraulic Fluid should i put in?
          93 S2 Avant Parting
          91 URQ RR
          02 A4 tdi Avant
          • Jas11n
            • 5067
            Only use the VAG green mineral fluid, part number G00 200 0 or as everyone calls it G00 2000.
            Can be had from VW and Audi dealers and also from GSF.
            DON'T put red ATF fluid in, or it'll rot seals.
            Jas
            2001 Avus Silver B5 RS4.
            1995 S2 Coupe - sold (sniff)
            • Knight Rider S4
              • 3541
              Cheers Guys .....parts coming tomorrow
              One more thing bleeding the pump after filling back up i take it there is only the +bolt that i am replacing that will bleed the system?
              ...........Steve
              93 S2 Avant Parting
              91 URQ RR
              02 A4 tdi Avant
              • Jas11n
                • 5067
                You shouldn't lose that much fluid, and it's self bleeding anyway. Just top up and do a couple of lock to locks.
