Guys anyone tell me how to change the top mounts please and what tools will I need??
Aaron
Aaron
) nuts and bolts hold the strut to the hub, 17mm on the tie rod end, 17mm on the arb links, and 10mm's for the bracket that holds the brake lines. You also need to undo the top caliper bolt (12mm i think) and push it out of the way to remove the strut bolts.
Dismantle the strut? Next you'll be telling me you have to take the wheels off!
