rs2 anti roll bar
  • nothelle300
    • Dec 2005
    • 201
    rs2 anti roll bar
    whats the difference between the standard s2 farb and a rs2 farb?Also another quick question how do i remove the front cv boot?Do you have to remove the calliper/disc??Last thing if the drop links were original on a 1990 s2 should they be plastic or metal?
    dean
    dean
    nothelle n300,alcon brakes,sachs suspension kit,lots still to be done!
  • 4WheelDrifter
    • Oct 2004
    • 5773
    • Country: Devon
    S2 FARB is 26mm, RS2 FARB is 28mm. ~35% stiffer.
    SS
    • nothelle300
      • Dec 2005
      • 201
      right ill have a measure up as the drop links have been changed from the standard plastic ones and lots of other bits had been done to the car the maybe(Fingers crossed)Its a rs2 one!how do i go about changing the cv boot please!
      many thanks
      dean
      dean
      • ericd
        • Nov 2003
        • 1240
        many thanks
        dean
        I'm assumming you've got the cv boot + grease + clips
