rack seals
  • Welleh
    • Aug 2005
    • 106
    rack seals
    just been down audi and bought a set of rack seals for my 91 3b coupe,
    was just wondering if anyone had the resources to check a p/n to see if it was all the seals needed to refurb the whole rack, its leaking due to a previous owner putting atf in i!
    p/n is : 895498020 other number on the page is V1803R1
    cheers
    Steveo~
  • s2avant
    • 2426
    That is listed as a set of seals for a servotronic steering rack so should be the proper kit for your 3B.
    You don't need to worry about the other number, iy is the order they used to order them from VAG.
    Ben
