rear arb fitting
  • vonbeck
    • 2455
    rear arb fitting
    is there any thing i should also replace when fitting whiteline rear arb? bushes links etc while im doing it ta very much
  • Azman
    • Sep 2005
    • 3205
    It should have come with bushes and two brakets for the flat bottomed bushes. If it didn't dont' fit it!!!
    Dark Grey Avant
    RS2 FARB
    Alloy Subframe Bushes
    • vonbeck
      • 2455
      yeh got them thanks i mean any other connecting bits ball joints and things
      • Azman
        • Sep 2005
        • 3205
        Depends what state they are in. Mine were okay so I left them.
        Dark Grey Avant
        RS2 FARB
        • vonbeck
          • 2455
          so its a case of suck it and see then? cheers buddy its f@£$*ng pi$$ing down at the mo so i might leave it till later in the week
          • nothelle300
            • Dec 2005
            • 201
            hi maybe replace the drop links if their original as they may be knackered!check to see how much movement is in the ball joint.
            dean
            nothelle n300,alcon brakes,sachs suspension kit,lots still to be done!
            • vonbeck
              • 2455
              ta, have you got the part number, and as always how much are they and from where
              • Ross
                • Aug 2005
                • 3399
                Rear droplinks at eurocar parts. GSF only do the fronts, unfortunately, at £19... think the rears set me back £55/pair! But still cheaper than the stealer, where i think they were £35 each.
                Ross
                • vonbeck
                  • 2455
                  cheers do you know if this is the part number 895505398 ta
                  • nothelle300
                    • Dec 2005
                    • 201
                    not sure about the part no,but their listed on ecp under rollbar components,
                    dean
                    • 4WheelDrifter
                      • Oct 2004
                      • 5773
                      • Country: Devon
                      Yes. The P/N for the rear drop links is 895 505 398.
                      SS
                        Get them from VAGParts, spoke to Alan sure it came too £70 for the pair OEM.
                        • vonbeck
                          • 2455
                          ta but £55 from euro is better dealer wants £36+vat each
                            No probs, eurocarparts are not OEM though.
                            • WabTheKing
                              • May 2004
                              • 2567
                              make sure you give the bolts a good soaking the night before with some diesel or sumthing similar otherwise they will probably snap like carrots then you have to fook about re drilling and tapping them, i speak from personal experiance (cough azman)
