Since I have purchased my S2 a month ago it is all about repairs and costly part replacement. On top of it I have to deal with inadequatly educated service people. One of the things that was bothering my from the beginning of my 'voyage, voyage' with S2 was the hydraulic system components - steering rack and brakes.
I had my steering rack repaired and the pressure bomb replaced by new VAG one. What I didn't know is that in no case red/atf oil should be used for hydraulic system (but VAG green G 002 instead). So I've been driving with that oil in my system for last few weeks and then I also replaced the hydraulic pump (it was leaking). Again red oil was pured in by 'technical' persons. Then I almost had an accident, my brakes totally failed on me - like the bomb malfunctioned and even worse - pedal became totally stiff and it became almost impossible to stop. Could it be of the oil ?
Luckily noone was hurt. I then learned through search on this forum that only audi G 002 oil should be used. I am going to use it now but my question is what should I now inspect and how to remove the red stuff out of my system completly?
