Strut Brace
  • Tonks4x4
    • Nov 2005
    • 3062
    Strut Brace
    I know it's not an S2 but other forums have not helped My 94 Cabriolet is not fitted with a strut brace or the welded mounts on the tops of the struts to mount one to.
    Does anyone know where I can get a polished stainless one to fit that does not require welding in?
    Or if anyone is breaking a car I can have the mounts off so that I can bolt them into mine. Or even as a last resort I will just have to make one..
    Audi Nut!!!
  • WabTheKing
    • May 2004
    • 2567
    omp do one for a 90/80 coupe for bout £40 which it bolt on
    but its red so you would have strip it and get it chrome plated, which would probably cost you in the region on £40 - £50 ish
    • Azman
      • Sep 2005
      • 3205
      If you speak to pete at Quattro corner, he can get the weld on mounts for approx £10 each and then you just need to source a bar to go across in whatever polished material you like.
      Dark Grey Avant
      RS2 FARB
      Alloy Subframe Bushes
      • RustyNut
        • 1433
        • Home: Zambia Current: United Kingdom
        Do you have a contact address for Quattro corner Azman?
        Old Stuff Reborn.
        • Azman
          • Sep 2005
          • 3205
          Yep just type quattro corner in on google and the contact will come up.
          Dark Grey Avant
          RS2 FARB
          • panzerwagen
            • 900
            "omp do one for a 90/80 coupe"??????
            Really? I thought OMP stopped making those bars for older Audi models? At least that's what I have been told.
            • WabTheKing
              • May 2004
              • 2567
              well pembo bought one for his rally car a couple of years ago, think he got it from demon tweeks,
              saying that they may have stopped and tweeks may have just has some in stock
              • Corey
                Banned
                • Sep 2003
                • 2793
                0121 4760034
                Corey
                01636 822288
                • BRY
                  • 3755
                  I found this on T'bay
                  • rotoryboy
                    • May 2004
                    • 3281
                    Didn't azman or someone get the top mount brackets replicated?
                    Mark
                    Race Clio RS197
                    S2 Coupe ABY (Green) - RIP
                    S2 Coupe ABY (Blue) - Sold
