I think I got to the bottom of the groaning and vibration on the o/s wheel, but not until after the n/s wheel started to make a scraping noise when turning right and I noticed that grooves were being cut into the disk
When investigating the scraping noise I took off the n/s wheel and found that the disk had about 10mm of side to side play and the caliper was touching the disk!!!
It seems that when the front wheel bearings were fitted 3 weeks ago the garage didn't fully tighten the big bolt that goes through the hub, the wheel bearing, hub carrier and into the drive shaft. B'stards.
The o/s wheel only needed 3/4 of turn to tighten it, but the o/s need about 5 turns. A bit worrying as I had just blasted up the M1 the day before at 120 and visions of the wheel coming off came to mind.
I found a local garage who checked with a VAG dealership and the bolts have now been tightened to 160nm plus a quarter turn, but I have just checked a workshop manual and it seems that they should actually be tightened to 200nm plus a quarter turn. Can anyone confirm what the actual torque should be for these bolts on a 1995 RS2.
All the groaning, vibration and scraping has disappeared and the car feels far better.
Thanks ... Angus
Thanks ... Angus
