Changing the steering rod
  • valjo
    • 1110
    • Country: Latvia
    hi there!
    i just came back from local vag dealer and i have bought g04000 oil. they said that it had replaced g020000 hydravlic fluid. does anyone know is that ok? could i mix old g0200 and new g04000 fluid?
    thanks alot
    valjo
    Audi Coupe S2 1993
    Audi V8 4.2 1993
    Audi cabrio 1998
    • s2dude
      • Nov 2005
      • 1631
      Originally posted by valjo
      hi there!
      thanks alot
      valjo
      Is it green??
      I would not mix with the 2000........
      One large bottle of fluid is enough for the system iirc
      • valjo
        • 1110
        • Country: Latvia
        yes it is green. and it is imposible to buy g02 in our country
        Audi Coupe S2 1993
        Audi V8 4.2 1993
        Audi cabrio 1998
        • Mikes2
          • 1704
          Yes G004000 is correct.
          Mike
          http://www.s2-audi.co.uk
          • kninio
            • Aug 2004
            • 641
            • Home: Lebanon Current: United States
            #20
            About flashing , yes undo the return line from the pump and start to feed the fluid box with new oil.. untill it become all new.
            About removing the steering rac. it have 8 bolts i think or six. two for the arms which turn the wheels. remove them. then remove the hydrolic fluid line. then u have i think two bolts in the chest on the rack which is bolted in the chest of the car , and two bolts behind the left wheel. and u must to free the steering column from the steering rack under near the pedals. brake and so on. and in the end u take it off.
            NOTE for Skull23 you are expert to understand my english. if u want more details contact me tonight and i will get u it 100% right
            • kninio
              • Aug 2004
              • 641
              #21
              Ok , in this picture is visible which bolts and washer u have to take of to remove the steering rack and the one which marked with nomber 2 is the one u have to loose from the steering column , inside the car. and i forget to mark the hydrolic pipe bolt.
              for diesel and 4 cylinders engines is very easy, Left hand drive.
              s2 and v6 i can see the steering rack in my dream only....
              • s2avant
                • 2426
                #22
                Here is the workshop procedure for removing the steering rack: Removing Steering Box
                Ben
                • Skull
                  • 3506
                  • Country: Slovenia
                  #23
                  I have removed a steering rack from a scrappy car. it is not really a mayor PITA (for a 4cyl engine), definitly not an engine-out or gearbox-out job. me and a friend menage to do this in an hour, counting that we did this for the first time. it requires removing the brake bomb.
                  Audi Quattro WR
