Coilover sleeves
  • quattro
    • Dec 2004
    • 768
    Coilover sleeves
    I have had a look but cant find a definate answer.
    Will the coilover sleeves from rallydesign fit my S2?
    Iv mesured my struts and im not sure if they will, any help would be good thanx guys.
    http://www.rallydesign.co.uk/catalog...oducts_id=3450
    Im allso thinking of 425lb/" front and 350lb/" rear, i know thats stiff but im not to concerned about 'Ride Quality' im only 22 not 52 lol!
    Probably the longet S2 project in history EVER!
  • WabTheKing
    • May 2004
    • 2567
    im running 400lbs x 8 on the front wouldnt want to go any stiffer, what height are you going to run it?
    if your lowering it id use a shorter spring and def shorter shockers as mine bottom out at the moment and my spring platform is adjusted right down to the bottom to,
    id probably look at say a 350lbs ish 6" spring for the fronts if your lowering
    • Pembo
      • Aug 2004
      • 295
      Try http://www.compbrake.co.uk. Steve is always helpful and runs his own track day Audi Coupe.
      Pembo
      quattro - Original 4WD rallying
      Rally Car photos
