I've been looking into the strut tools needed to replace my shock absorbers.
The VW/Audi tools are VW524 and 3078.
I found this 3 piece kit and was wondering if the item pictured on the left can be used in place of the 3078 tool? I'm not sure if it could be a 22mm socket with a hex end at the top to attach a spanner to and insert the hex in from above?
The 3078 tool is essential a large 22mm deep socket with a window to allow a 7mm hex key to be inserted to stop the damper arm from turning.
EDIT: Oh I'm being silly it's three items and they are all the same. Is there an alternative to using the 3079 tool?
Thanks,
Rob.
Thanks,
Rob.
