power steering fluid level
  • s2_southwest
    • Oct 2004
    • 823
    Just had a little look at my PS fluid level, but im a little confused. Ive opened the cap which has the spring located inside but where should the level be? should it be topped up? bit silly but i've looked in the dark, should i be able to see a level through the clear plastic of the header tank?
    cheers
    Pearl white 91-S2-3B K&N cone air filter - Home made induction pipe work - 18" RS4 replica alloys - Yokohama Parada Spec 2 rubber - Colour coded body work - Bilstein/H&R suspension - s/s 3in turbo back Longlife exhaust - SFS water hoses - Samco boost hoses - RS2 FARB - RS2 eyeballs - Squeaky interior trim & 2 bar!
  • MidnightBlueS2
    • Jul 2005
    • 1653
    • Home: United States Current: Belgium
    Yeah, in daylight you'll be able to see a MIN - MAX level embossed on the p/steering bottle...
    HTH,
    David
    Midnight Blue S2 - SOLD - 1993 S2 Avant
