My car has started to tramline quite badly! It seems to have started after fitting the 5mm wheel spacers to the front end. I was wondering if i should do the same to the back end? Not sure if this would help?
Also the steering 'feel' changes. sometimes it feels nice and heavy and then sometimes it will change to super light mode! I have the servotronic module unplugged. Im thinking it must be the valve in the rack sticking or something? I dont want to remove it as the seals are not available! And knowing my luck they will break when i take the valve out
Any one had this experience?
Then I had the 4 wheel alignment done (£50
But never buying Badyears again they cost me a fortune. So swap your boots round before going mad with the plastic, wish i had.
Wish it was something simple, will try swapping tyres front-rear and see if that helps! But im almost certain its inside the rack itself
