Clunking
  • s2avant95M
    • 1217
    • Home: England Current: United States
    Clunking
    Ok, I know there are loads of threads on clunking noises but I just wanted to find out for sure what to check for in my case.
    Clunking happens sometimes on full lock, mainly from front left side, mainly while stationary but can happen at low speeds.
    Clunking happens sometimes on hard braking mainly from the left side.
    I have jacked up the car and can turn the springs, is this right? Only a few cm's either way from the locking position.
    Top mounts changed (blue), new wishbones, new ball joints, new ARB droplinks.
    What else should i look for to solve this annoying problem.
    Any help appreciated.
    Tim
    1995 S2 Avant, ruby red - ** SOLD TO ROSS **
    Golf Rallye G60 ** SOLD **
    Golf MK2 Oaky with R32 engine
    Audi A6 Avant 1.9 TDi 130
    Golf MK2 8v Race car
  • ericd
    • Nov 2003
    • 1240
    you checked the condition of cv boots and steering rack ?
    • s2avant95M
      • 1217
      Not really. Although it was MOT'd less than 3 months ago. Am i just visually checking or are there tests to see if this is the problem?
      Tim
      • ericd
        • Nov 2003
        • 1240
        I'd do a visual check the boots can go at anytime, quick look at inner wheel rim usually where the grease from the cv boot ends up if it's leaking, only takes a few mins under the car to check them out
        HTH
        • s2driveruk
          • 12696
          for what its worth my springs used to move on the perches and sometimes make a 'twang' noise...even after changing them to h&R's they can move a little
          1992 3b S2 Coupe
          • Markarina
            • Mar 2006
            • 511
            • Home: United Kingdom Current: Switzerland
            top suspension mounts ?
            • s2avant95M
              • 1217
              Yes, blue top mounts new ^^^ in Febuary this year. Also new H&R's and RS2 shockers last December.
              Tim
              • mark_s2
                Account Disabled
                • Jul 2006
                • 274
                Dont know if this will help but I had this problem on my brother's RR-UR when we changed the wishbone bushes.
                Turning from lock to lock would get a clunk that was audible and could be felt through the steering.
                Turns out the bolts that secure the wishbones need to be torqued with the weight of the car on them - this is not easy to do especially without a pit.
                • s2avant95M
                  • 1217
                  When i put new wishbones on they were torqued (with great difficulty )while the car was on the ground. I am going to double check these bolts though tonight.
                  Tim
                  • RAOUL
                    • Sep 2003
                    • 260
                    Hi Tim, I used to get a clunk at low speeds just before i had my propshaft refurbed. A rally mechanic i know told me to split the cv joints clean them out ( jizer bath if you have acess) and re-grease them. Only did the outer ones. This did the trick. Also if youre front tyres are getting worn I noticed this seemed to affect low speed turning, daft as it sounds!!!
                    Best of british!!
                    Raoul.
                    ATB
                    RAOUL
