What have i done wrong?
  • markrs2
    • 185
    Hi All,
    Fitted new wheel bearings to the rear of my RS2 yestereday and now the rear of the car "shimmies and skips sideways" over lumps in the road. I removed the wheel bearing housings in order to replace the bearings and fiited them back to the car in what i thought was the correct way ie:
    1) fit bearing housing to lower wishbone with the housing upright and loosely fit camber adjusting bolt.
    2) connect the top wishbone to housing bolt and tighten
    3) connect ARB drop link to housing loosely
    4) connect track control arm to housing and tighten
    5) put the cars weight on the suspension and then tighten ARB drop link and camber adjustment bolts.
    I know the camber is probably out but I did not thing that this would cause this problem?
    Any ideas as to what i have done wrong?
  • s2dude
    • Nov 2005
    • 1631
    Originally posted by markrs2
    Hi All,
    How have you pressed the new bearings in?
    any pictures of the setup?
    • markrs2
      • 185
      Pressed the bearings in with a 15t hydraulic press as i usually do and then went in fine as did the hubs!
      No pictures of the setup but it looks exactly the same as when it came off and the diagrams in ELSA
      • s2dude
        • Nov 2005
        • 1631
        Are you sure the bearing is correct? Did the brake disk line up fine in the caliper carrier (eg/ equal gap on either side)
        Wheels are on and all bolts torqued up?!! (obvious I know but its been done before!!)
        Are your ball joints or drop links knackered?
        • WabTheKing
          • May 2004
          • 2567
          sounds like your tracking has gone out, go and get an alinement check - i have had this problem before
