Front suspension general stuff....
  • Martynf
    • 1885
    Due to a little 'mishap' with my front suspension, my S is currently sitting on axle stands dead for a little while :wacked:
    The left hand front wishbone ball joint is completely fooked and needs to be replaced (which was the source of my knocking noise over bumps). So whilst i'm fitting a set of cast wishbones, RS2 front ARB and new drop links anyone suggest any BTDT's for putting all these bits on? like...
    The RS2 front ARB, do you do up the two front clamps ONLY with the car on the ground? same with the two droplinks, do them up on the ground? or in the air? ball joint pinch bolt? in the air or ground?
    Any other do this or thats greatly welcomed
    I was sitting there with wishbone removed, drop link in hand and thinking, hmm... this would be a great time to fit new front shocks at the front, that means I'll have to do the rears as well. Might as well put new springs on too whilst I'm at it, maybe H&R's, ar, and whilst the lot is off, I could do the brakes, but that means bigger wheels... one coffee and two fags later, Mr access card committed suicide at my thoughts and they now remain just that! thoughts.... in for a penny, credit card out for a grand!!! But not this time! I resisted the urge! must be getting old...
    Martyn
    Martyn
    www.vagparts.com
  • jubjub
    • Nov 2003
    • 1239
    Re: Front suspension general stuff....
    Martyn
    Go on, go onnnnn....you know you want to!!!!
    • Martynf
      • 1885
      Thank you! I don't need any encouragement thanks! NOPE, I SHALL be strong. I can resist, I can resist.....
      Martyn
      www.vagparts.com
        Martyn, while its off why not.
        You could always tackle the front this week and the back next.
        when fitting the RS2 ARB fit the drop links to it but dont fit the clamps on subframe until the car is on the ground.
        Also worth puttin a bit of copper slip on ARB where it fits around bushes.
        • Doug_RS2
          • 3847
          What are you doing mucking about with the dirty stuff - have you finished fitting the RS2 interior?
          • porkkis
            • 1994
            Tighten the ARB to sub frame bolts wheels ON the ground. Ball joint pinch when ever the easiest = off the ground and wheel off.
            Note that you must get wheel angles realigned as the camber is set moving the ball joint.
            Avants don't have cast wishbones as standard?! Why change the wishbones?
            Enjoy the coffee, I know the feeling.
            • audiman
              • 4827
              Everything can be fitted in the air, the only bolts that need doing up tightly when on the ground are wishbone to subframe bolts. Everything else can be tightened when jacked up.
              Well, if I was you, shocks and springs would be a must and just save up for new brakes and wheels. Get it handling spot on. Also when you have replaced all these bits, like the wishbones etc, you will need 4 wheel alignment done. It will have to be done again after fitting the shocks and springs. you maybe saving money for the moment, but at 50 quid a throw its another 50 quid saved that could go towards the suspension bits!!!!
              Not that i would try to make you spend your money. Just tell the wife some ******** and she will never know! If she thinks the car is lower afterwards just say it was all the extra grub over christmas and that she must have put on weight, that should keep her quiet!! LOL
              Tom C - www.rcmr.co.uk
              Audi UR Quattro
              Audi 100 C3 2.0 5 cyl 115ps
              Audi B5 RS4 645ps 911nm
              • martinjs
                • 3205
                Yeah martyn, have you fitted those seats or wot!
                • desmo888
                  • Oct 2003
                  • 390
                  Martyn,
                  If using used wish bones, be sure to replace the bushings regardless of what they look like. It is much easier to do it now while you have them off any way.
                  You can do it at home. The biggest PITA is getting the old ones out. Let me know if you need some tips on that.
                  So...sounds like my shopping list just got a bit longer. I have to get that RS2 bar!
                  What is the recommended rear ARB? I bought all four wish bones from a later Coupe than mine. It included cast front wish bones, stamped rear ones and a rear ARB about as big around as a damn pencil!
                  Seems hardly worth installing.
                  Also, are there cast arms available for the rear? I swear my 20v 7A sedan had cast rear arms.
                  As far as tightening sequence, the wish bone attach points MUST be tightened with WOW (weight on wheels). The ARB to subframe bolts must only be tightened with WOW if using rubber bushings. Rubber sticks to the ARB and will load up if tightened in the air. IF using poly or Delrin bushings, it doesn't matter as the ARB can rotate within the bushing.
                  Anyway best of luck in resisting the urge!
                  Dave K.
                  USA
                  1991 e//S2 (home built S2 - the only way to get one in USA!)
                  2001 S4
                  • 91_S2
                    • 612
                    Whiteline BAR14Z rear ARB is a bolt on for S2's. Gives equiv. 20mm instead of original 17 mm. Around 300 Aussie bucks plus shipping. Check out the rear ARB thread on this forum.
                    http://www.whiteline.com.au/
                    Quite a few of us have it. All love it.
                    • Martynf
                      • 1885
                      Thank you VERY much guys!! oh how tempting to do the shocks, but I just cannot afford to... we go to Australia for a month! on the 12th Feb, and every penny has gone into that huge holiday bill!!
                      Damn the tacking neededing doing again i just spent a good few hundred quid getting that sorted in November
                      The forged arms I got as a good buy off e-bay already fitted with new bushes and new Audi ball joints, so cannot complain about that! I might... get powerflex's new all polyura what ever its called!! bushes, the ones without ANY metal at all!!! we'll see.
                      Thank you VERY much for the great advice guys
                      Martyn
                      Martyn
                      www.vagparts.com
                        Yeah Martyn - the RS2 ARBs are worth doing... but like all critical points on the suspension shouldn't really be tightened up with the wheels in the air... as everything gets stressed and twisted when the weight of the car is restored to the suspension.
                        You can get away with tightening up the ball-jointed droplink fitting as that joint will just rotate.
                        Also top mounts in 'blue' if not already done...
                        Paul
                        • desmo888
                          • Oct 2003
                          • 390
                          Thanks! I'll have to check it out (and see how poorly the American dollar is doing...)
                          Dave K.
                          USA
                          2001 S4
                          • Martynf
                            • 1885
                            Cheers Paul!
                            Sounds like Mr Breeze blocks are coming out to play so I can lower the car onto its wheels and still get under neath to get the wishbones nuts done up through the subframe. How the hell you do this with the wheels actually on the ground I do not know!! Blue tops are fitted and I opted for the metal RS2 droplinks this time.
                            Thank god for nut splitters (drop link nut welded on!) and copper grease I say!
                            Martyn
                            Martyn
                            www.vagparts.com
                            • 91_S2
                              • 612
                              Are there hard plastic bushes for the RS2 front ARB? PN anyone?
