Wheel Bearing issue
  • NorrS2
    • May 2004
    • 210
    Wheel Bearing issue
    My S2 avant is now about to have it's third Wheel Bearing on the same rear wheel in the last year . The first two were fitted using a proper press by the same garage (I thought the first replacement must have been from a bad batch). The car went to the Audi dealer in February/March for a 4 wheel alignment and I got a call to say "we can't track the car cos this wheel bearing is shot"! So I order another and this time it's fitted by the dealer and 5,000 miles later it's *hagged again.
    Has anyone else had a similar experience? or does anyone have any idea while this same rear wheel is doing this?
    95 S2 Avant Ming Blue - now gone and sorley missed:cry:
    2001 B5 RS4 Santorin Blue - MRC'd - now here:chit:
    88 Ur MB Quattro -Pearl White - The daddy!:cool:
    Classic S2 Avant billboard ad - "My other car's a Porsche, but today I'm in a hurry"
  • Fat Audi 80
    • 10547
    Is your suspension / hub okay? Do you have any tyre wear. It sounds like something is out of line and destroying your bearing. You WOULD notice this on your tyre too though.
    Just a thought...
    Cheers,
    Steve
    The Perfectionist
    • twoqu
      • Sep 2003
      • 3103
      Considering wheel bearing last for over 100K, something must be up!
      Although the garage may have a proper press, have they used properly? It is essential that the inner race is supported when the hub is pressed back into the bearing. Another critical issue is that the hub bolt be tightened to its specified torque with the vehicle on the ground so that the full weight is present on the component!
      Certaintly need to inspect the hub itself as well. When the hub is pressed out its usual for the inner race to stay on the hub. The proper way to remove this is with a two legged puller. However its not unknown for people to resort to angle grinders or cold chisels!
      If an Audi dealer fitted a genuine part correctly then I don't think its unreasonable to ask the Service manager how it has failed after such little use. Think there was a discussion recently over the replacement of the bolt as it is a stretch to yield and therefore only suitable for use once. Check your receipt to see whether this was replaced.
      • baltiboyS2
        • 965
        Hi there norr s2 there most likely culprit would be the flange you insert into the bearing with the studs on it these have been knowen to been worn badly i changed a wheel bearing on the front of a boys 16v coupe only for the bearing to knakered within 500 miles initially they flange seemed ok but on later inspection you could see were had worn away.
        Changed the flange hey presto it seemed to have cured the problem well he has not complained about the bearing and he has covered about 1500 miles since i did it last year
        Raj Aby
        • caterpillar
          • 2480
          you have to opent the bearing, so you can have som deasent grease innside... the org grease are som *****- use the mobil xhp 222. its the only blue bearings grease i know about.
          • NorrS2
            • May 2004
            • 210
            As usual, I've had more ideas/possibile problems identified here in the proverbial 5 mins than half the stealers/garages in the country Obviously, should have come here first
            Thanks guys, I'll follow up on all your suggestions prior to the next one being fitted.
