power steering pump
  • fidoe
    • Mar 2006
    • 75
    power steering pump
    hi,
    the s2's in for a service and (amongst other things) needs a power steering pump replacing. the quote I've been given for a replacement part is £225-250 - anyone know whether that sounds reasonable?
    The place servicing it is TAP Audi who I've been assured are very good, but just wanted to check...
    any help would be much appreciated,
    cheers
    John
    95 ABY Coupe...back on the road with new engine/oil cooler and bonnet!
  • S-Express
    • Nov 2006
    • 1133
    There's excellent step by step re-build instructions on here somewhere........
    • fidoe
      • Mar 2006
      • 75
      would try it but don't have the time/expertise/equipment to attempt it at the moment...
        Yes theres a post by Graham.
        If you speak to Sal or Bry they should be able to get you a good unit for half that (if that! ).
        Depends if theres is new or not.
        • Graham
          • 1622
          The re-build post is HERE
          • Azman
            • Sep 2005
            • 3205
            Got one up for grabs at the moment as stripping my car for an update ( got 2 coupe's)
            PM me with an offer for it!!!!
            Az
            Dark Grey Avant
            RS2 FARB
            Alloy Subframe Bushes
