Heat the copper washers up with a torch and they will be good as new (soft again)...
Advice on pipe from the steering rack needed
Thank you Error404 - that does help.......I thought the gauze and little hole in the bolt served a specific purpose - so thought bes to get the same.
Fortunately another RS2 owner here has a spare, so getting it from him. Hopefully I don't mess it up this time. I think I messed up the bolt, when replacing the X plug
So replaced the bolt - and guess what it continued leaking, removed the bolt and the threads are damaged again - see pic. My dilemma is how do I clean the threads on the pump, which I assume is damaging the bolt, without dropping any metal filings into the pumpOriginally posted by Mr GThank you Error404 - that does help.......I thought the gauze and little hole in the bolt served a specific purpose - so thought bes to get the same.
Sent from my iPhone using TapatalkComment
Just an update - managed to get a generic banjo bolt 10x1 BTW, without the filter in it. I cleaned the threads on the pump, put in the new bolt and no leaks
I still need to do a pro longed drive and some stop go traffic to fully test. THANX for the advise, input and help - much appreciated.
Orsum - apologies once again for railroading your threadComment
