Hi all,
Started to replace front wishbone bushes today, all was going well untill one rubber bush came away leaving the outer metal sleeve still in the wishbone, which we tackled with a hacksaw and yip you've guessed it, went a bit too far with the hacksaw and ended up cutting into the wishbone approx 1 mm deep
! Now the question is has this weakened the wishbone and should i replace it or would it be okay to reuse ?
( Btw, wishbone is the cast one - on RS2 )
Thanks,
John.
! Now the question is has this weakened the wishbone and should i replace it or would it be okay to reuse ?( Btw, wishbone is the cast one - on RS2 )
Thanks,
John.
