I just bought a set to fit the rs2. Upon opening the boxes I noticed that I can push the rods of the shocks in and out and there is no rebound. Is that normal?
Koni shocks
yes the same.
looking at a few forums I noticed that they do appear to work that way.
do the fronts adjust with a knob or by pressing fully down?
for the rear I suppose you adjust them but you can't do that again once fitted without dismantling as the adjuster area lies within the tube
also noticed the front are internally adjustable onlyLast edited by A80Avant; 16 March 2018, 14:31.
Front ones pressed fully down, and turn clockwise (firmer). Rear ones could adjust/turn with metal pin and turn counter clockwise (firmer)
Maybe this helps: http://www.koni.com/en-US/Cars/Techn...stment-Guides/
Both ones adjustable externally.Last edited by jax1; 16 March 2018, 15:07.
Stock springs
-1.5F -1.0R
H&R springs
-1.0F -0.5R
Where
-x.x = counter clockwise turns from fully hard (wound in clockwise).
F = Front
R = Rear
Looking at this am I reading something wrong or getting a mind freeze?
for the rears and stock springs, am I turning first fully counter clockwise to fully firm then -1.0 turn (ie 360deg) to get the above setting?
On the contrary, the fronts are first turned fully clockwise to reach fully firm and then -1.5 counterclockwise?
