Front an rear subframe re-fresh
  • tango123
    • May 2017
    • 892
    In the next couple of months i will be carrying out a front & rear subframe re-fresh.
    Just want to pick your brains on the essential bits i'll need.
    I have new front and rear subframe bushes and the 4 main Bolts for both frames as they are stretch bolts, so i have read.
    Are there any other bolts etc, that are common to seize up and worth replacing....?
    Thanks in advance
  • piotr
    • Jul 2012
    • 1470
    I would just allow some extra time as you might find they will need some welding.what bushes you will use on them?OEM or power flex etc?
      • Dec 2017
      • 5983
      Piotr is correct. I'm finding most of my suspension rubber parts are perished or cracked and need replacing. You may as well do your fuel filter, fuel and brake lines while you are there as well as the tank straps and under body protection. When the subframe is off you have easy access to all these things and it turns into a big job
      • tango123
        • May 2017
        • 892
        Hopefully they arent that bad. I have oem for the front an will get powerflex for the rear subframe, as i couldnt source any oem for that.
        • hunker7
          • Mar 2014
          • 3487
          I am planning similar work and I will be replacing all the bolts/nuts with zinc coated 10.9 spec and replacing brake lines and dropping fuel tank to check for rust/holes and get it cleaned up and painted. Allowing myself 2 weeks to do all the work. But I have spare differential and subframe parts which will be ready to go on.
          '93 Audi UrS4 Avant
          '15 Audi A7 quattro 3.0 TDI
          • steve briance
            • Aug 2014
            • 1455
            where did you get the stretch bolts from? I thought audi were the only source and they had become no longer available...
            • tango123
              • May 2017
              • 892
              I was thinking about stainless steel nuts/ bolts.
              How do you know which ones to get as in thread sizes etc?
              • tango123
                • May 2017
                • 892
                From ecs in the states.
                • mackenzie50
                  • Mar 2010
                  • 740
                  I got my bolts for both subframes from QuattroCorner last year.
                  • hunker7
                    • Mar 2014
                    • 3487
                    I've reused bolts and they're fine. I use 7zap that usually will state size, thread and length and then just eBay the size and voila.
                    '93 Audi UrS4 Avant
                    • piotr
                      • Jul 2012
                      • 1470
                      I found the four OEM main subframe bushes to be very difficult to instal in even with plenty of lube.The hard rubber lip just start to split up when I was trying to push it in with press. Maybe it was just combination of my bad day and excess of powdercoat.
                      • tango123
                        • May 2017
                        • 892
                        i might just get someone else to do that bit as i know its a nightmare.
                        • eJaYr
                          • Nov 2009
                          • 81
                          • Country: Poland
                          What about snapped bolts? I snapped first one I’ve touched
                          • tango123
                            • May 2017
                            • 892
                            which bolt has snapped?
                            • eJaYr
                              • Nov 2009
                              • 81
                              • Country: Poland
                              Rear corner of my rear subframe
