Hi All,I've had the following problem for approx 12months, roughly 7 out of ten times when starting my 91 S2 for the first time that day the steering wheel is hard to move and it kicks back quite hard when I try to turn it to pull out of my drive, I find if I gently rev the engine the problem goes away and the steering feels and behaves normally again, the warning buzzer sounds sometimes but not everytime this happens,the problem has on the odd occasion happened twice in the same day, but then again some days it doesn't play up at all, I did top up the p/s res with the recommended fluid, the p/s pump is quiet and there doesn't appear to be any leaks..anyone got any ideas about this problem please...
Thanks in advance.....Alan.. aka Condor..
