Brake caliper
  • brelum1
    • Dec 2015
    • 34
    • Country: Norway
    Brake caliper
    Hello!
    Can anyone helpe me find out wich caliper this is?
  • 90quattrocoupe
    • Nov 2003
    • 771
    Need a picture.
    • brelum1
      • Dec 2015
      • 34
      • Country: Norway
      • brelum1
        • Dec 2015
        • 34
        • Country: Norway
        • brelum1
          • Dec 2015
          • 34
          • Country: Norway
          • brelum1
            • Dec 2015
            • 34
            • Country: Norway
            • brelum1
              • Dec 2015
              • 34
              • Country: Norway
              Pictures :-) forgot it first
              • kj6304
                • Nov 2016
                • 51
                • Home: Hong Kong Current: United States
                What is the part number below the Brembo logo ?? You can use that number to google and or members here can help.
                • brelum1
                  • Dec 2015
                  • 34
                  • Country: Norway
                  The only numbers that are om them are :
                  -207673032
                  -3a1312
                  I can’t find anything online with these numbers?
                  • mac2226
                    • Jun 2008
                    • 1289
                    They look like Porsche Cayenne rear 4 pots
                    • brelum1
                      • Dec 2015
                      • 34
                      • Country: Norway
                      Ok thanks for help :-) do you know what i will need to use them fore front brakes on my 90 s2 coupe?:-)
                      • mac2226
                        • Jun 2008
                        • 1289
                        Hi brelum I wouldn’t bother using them on front there made for back the pistons are small. What you want is the Porsche Cayenne front calipers 6 pots and buy the brackets for both calipers from ak motorsports. Also will say which discs to use with the brackets
                        • brelum1
                          • Dec 2015
                          • 34
                          • Country: Norway
                          So i cant use these in front ? Are there no brackets for these in front ?
                          • mac2226
                            • Jun 2008
                            • 1289
                            Like I said above these are made for rears for Porsche Cayenne you could make some brackets for fronts. You can buy the matching front calipers from ak Motorsport as well as brackets discs everything you need to bolt up to your s2 coupe all best Michael
                            • _ShurikeN
                              • Mar 2010
                              • 733
                              • Country: Russian Federation
                              You can but you should not. Piston diameter is too small.
