last night i replaced the front brake pads and had a quick look on suspension and found my 3years control arm bushings torn out.i have an idea to upgrade them with the poly bushing since i'm tired of replacing the same bushing every couple years.I have read some threads and found the snapped sway bar issue after upgrading with the Delrin bushings.Will this likely to happen with the Poly (Street or Track ) bushings?I'm leaning toward the Bushings off Albert(AKmotorsport).i think the Delrin is way too solid and caused the lack freedom of movement until the swaybar snapped?TIA.
Poly control arm & swaybar bushings upgrade on C4.
Tags: None
I've bought AKmotorsport red street density as i din't want anything harsh. I've not fitted them yet but just checked them again and they're compliant enough so shouldn't cause any issues with snapped anti-roll bar in my opinion.96 URS6 plus speck saloon
