Front subframe bush part no.
  • Front subframe bush part no.
    Please could I ask for a little help
    I am looking to purchase new front subframe bushes
    I have checked the part no. and got 8A0199415B and 8A0199419A. 2 of each.
    Looking on Audi Tradition, they list the first no., however the second is not available
    They do, however, list 8A0199415A, which looks correct in the pictures
    I am very aware that the part no. must be exactly correct, but are these the the right ones?
    Thank you in advance
    Audi RS2 Volcano Black, MRC chip, Milltek exhaust
    The first two parts numbers are for M12 bolts. The part number ending with 415A is a bush for M10 bolts.
      Thank you Nuvo
      Looks like, as I suspected, I need the correct no.
        Go AK street. Easy fit and won't rot. I couldn't find originals for my Avant so went AK front and rear.
          Thanks Tractor Dave
          I was trying to go original, but if they are not available then the AK stuff looks good
          Are the bushes the same front and rear from AK?
            The rear ones on the Avant/RS2 are much bigger than the front. He does a kit for front and rear in either street or track. I've done the whole car in his street and I'm very impressed with the fit. I haven't had a go on the road yet as my car isn't finished. Albert is also very helpful and gave me advice when I got stuck with one of the rear arm bushes (on a Sunday). They are quite a bit cheaper than polybush/powerflex as well.
              AK bushes just fitted on my rear subframe.
                And the front subframe.
                  I managed to get new stretch bolts for the front subframe from TPS but I was told the rear ones were NLA. Luckily, my old ones looked good so I was able to re use them.
                  My anti roll bar bushes are Powerflex. They came with the car and were street so I used them. A full set of track Powerflex bushes also came with the car but I decided they would be too firm for me and are now happily owned by another forum member.
                    Thanks Tractor Dave
                    I couldn't just find the rear kit, because I was looking for red ones which I though were the street grade. Found them now
