I have a question, is if possible to plug the one i have mark in this picture on my servopump?
Need help with power steering pump S2
That's the brakebooster side. What I have red is that if you're planning to plug that you'd have to take those pistons and springs away. Those are behind those 2 caps on the front section of the pump (relatively big + socket)
Hope it won't damage the pump in anyway as I'm going to go that route very soon on my vacuum brake booster conversion...
-93 Audi S2 Coupe ABY
-74 VW Type 1 1300 (2110cc)
-97 VW Golf VR6 Syncro as a daily driver
https://www.lokoverkkaritalli.com -
PM ser att du är Svensk?That's the brakebooster side. What I have red is that if you're planning to plug that you'd have to take those pistons and springs away. Those are behind those 2 caps on the front section of the pump (relatively big + socket)
Hope it won't damage the pump in anyway as I'm going to go that route very soon on my vacuum brake booster conversion...Comment
