RS2/S2 cv joints worn
  • joss01
    • Apr 2019
    • 384
    Can anyone help me with either finding a replacement driveshaft I need one front and one rear shaft, is there an alternative available apart for refurbing the original units
    • Dec 2017
    • 5991
    Hi Joss
    Your shafts will be fine unless the car had been in an accident. Easy job to replace the CV joints inner and outer. Front and rear no problem. Get good quality ones. SKF are good and now you can buy direct. Check my 're build thread as how to. Messy but not difficult
    • joss01
      • Apr 2019
      • 384
      thanks for the help I will go down the route of changing the cv but there is only one type of cv joint replacement available do they work for both front and back shafts
