RS2 alignment specs
This is a sticky topic.
  • alg
    • Apr 2004
    • 1160
    RS2 alignment specs
    Anyone got the OEM specs ?
    Just had mine setup using S2 avant specs and -1degree chamber at the front. Still feels a little odd ? just previous front nearside tyre abnormal wear settling ? Turns in sharper but feels less stable with slight pull to kerb.
    Guy spent some time setting it up with me looking over his shoulder. He only had coupe settings in machine but mannually put in avant specs.
    Rear had been out of alignment for some time by a degree so overall better just not perfect
    Alastair
    RS2
  • Jas11n
    • 5067
    Huh? you asked this the other day. Is that page from the manual I posted incorrect in what it says? be good to know if it is
    2001 Avus Silver B5 RS4.
    1995 S2 Coupe - sold (sniff)
    • alg
      • Apr 2004
      • 1160
      Sorry I missed your reply Jason Thanks
      Alastair
      RS2
      • GlynRS2
        • Dec 2003
        • 307
        RS2 Suspension Alignment Values
        FRONT:
        Caster front:
        Recommended value +2,10º
        Max difference left/right +0,30º -0,30º
        Camber front:
        Recommended value -0,45º
        Toe front:
        Recommended value +0,07º
        Max difference left/right +0,05º -0,05º
        Toe total front:
        Recommended value +0,14º
        Max difference left/right +0,10º -0,10º
        BACK:
        Camber back:
        Recommended value -0,40º
        Max difference left/right +0,20º -0,20º
        Toe back:
        Recommended value +0,05º
        Toe total back:
        Recommended value +0,10º
        Glyn
        Ex-Polar Silver RS2
        Sprint Blue RS4 - new toy :mischeif:
        • europeanme
          • Oct 2005
          • 3817
          I am probably being an idiot but why are the S2 avant and RS2 different....would it be a bad idea to use the Rs2 dimensions on an S2....one thats been "tweeked"....
            Different shocks, Different size OEM wheels ( 17 instead of 16 and 245 instead of 205 standard ) Different offset on wheels due to porsche hubs.
            • europeanme
              • Oct 2005
              • 3817
              I have just compared the details from S2 central and the info Jas11n posted and they have the same figures on...
              I am a tad confused....might leave it up to the alignment guy tomorrow....
                Be careful as the place will have more than one alignment values. When I had mine done I had to ensure they used the sports suspension values not the stock audi 80 values.
                • europeanme
                  • Oct 2005
                  • 3817
                  Shark_90 has used the same people i am going to see tomorrow..so hopefully they will already have figures...
                  I will take the figures found on here down just for information in case they need them...
                  cheers for the tip Jamo....ADi??...
                  • alg
                    • Apr 2004
                    • 1160
                    I should add that this set up works !!!!!!!!!!!!!! My problem was the worn tyre
                    Alastair
                    RS2
                    • PaulJ
                      • Jun 2008
                      • 253
                      RS2 Alignment values with tweaked suspension
                      FRONT:
                      Caster front:
                      Camber front:
                      Toe front:
                      Toe total front:
                      BACK:
                      Camber back:
                      Toe back:
                      Toe total back:
                      Hi All
                      Is the above set of values the best to use with tweaked suspension, by tweaked I mean
                      HR Coilovers, Neuspeed Rear ARB, Polybushed,
                      Any point going a bit more aggressive on front, ie bit more camber and as much
                      castor as he can get in the standard setup
                      Going in next week for alignment and wan't to check out the best set of figures
                      Cheers Paul
                      1995 RS2 Nogaro
                      1971 Lotus Elan Sprint
                      1974 Lotus Elan+2S 130/5
                      • Skull
                        • 3506
                        • Country: Slovenia
                        Anyone knows what is the max camber on the rear of the avant/limo with stock eccentric bolts?
                        Audi Quattro WR
                        • pw-rs2
                          • Oct 2008
                          • 72
                          From my experience most tyre shops that use electronic data systems don't list RS2 settings. Also some only list S2 settings for coupe not avant. Every time i've had mine checked on my RS2 & my S2 avant i had to give them the settings to put into there machine manually.
