Holy ****!!! SOS
  • Graham
    • 1622
    Holy ****!!! SOS
    Hi guys, tonight coming home from work my steering went vague, i could turn right with the usual accuracy, but when i turned left doing 40mph ish i could turn the wheel 30 degrees before anything happened then it caught up with me. had a look when i got home and found this in the pic below . I need a new one or a replacement asap, i will take this one off at the weekend and weld it up next week at work to do till a new one arrives, If anyone has one available pm me asap, as this is well dodgy.
  • quattrostyle
    • Oct 2006
    • 6229
    I've got that part but it won't be expensive when new I guess?
    • s2driveruk
      • 12696
      blimey that was a lucky escape!!!! Unusual for it to break I'd have thought, personally would check everything linked to it (rack, rods etc) to ensure nothing is adding an extra heavy load or torque to it.
      David
      1992 3b S2 Coupe
      • Graham
        • 1622
        David
        I believe my strut tops are a bit fooked, so i have ordered a set of these, plus lately i have been doing some hellish cornering showing these ozzie V8's how a car handles, also she has had a hard time with kerbs and extra deep drains lately, just glad only one side broke.
        Graham
        • s2dude
          • Nov 2005
          • 1631
          Graham
          Holy sh*t mate!!!
          Close call. And very lucky only one side broke for sure.
          • Jeffer
            • 2057
            how the hell did that happen!?!? You're a lucky man. Those things are really sturdy, can't see why it would fail by fatique..
            RS2 Black - stock 315 HP
            RS2 RS blau - stock 315 HP
            Sport Quattro - 1005 HP
            High Octane website
            • Sir Buff
              • May 2004
              • 127
              • Current: Switzerland
              This is a well-known problem.
              http://www.audi90.ch
              • iain1067
                • 984
                never seen or heard of that before
                iain
                • spink
                  • 4382
                  me neither,scary
                  • Graham
                    • 1622
                    Right, got it off and found the cause of the problem, it has indeed fatigued, the 2 bolts going through the bracket onto the rack i thought would be fit bolts with captive nuts on the bottom, but now it is off the rack itself is threaded, so i have been checking the torque on the bolts thinking they have been tightening against the nut pulling the whole lot together, instead they have been tightening against the rack so only the top side is secure, the bottom must have been not to the correct torque. Lucky is not the word. It only took 6 mins to get it off like
                    • Corey
                      Banned
                      • Sep 2003
                      • 2793
                      811 419 325 B
                      Retail is £18.42
                      Corey
                      01636 822288
                      • A1QSHIP
                        • Aug 2004
                        • 975
                        Graham
                        You would think that as easy as we all drive these cars that such an "unstressed" ten to fifteen year old part would hold up better.
                        I have ordered a new one with new hardware from the dealership.
                        "Nulla tenaci invia est via"
                        • s2driveruk
                          • 12696
                          think I might go check mine now.....
                          1992 3b S2 Coupe
                          • Keeper of The Kitten
                            • Dec 2003
                            • 2317
                            Jeeeeeez!
                            That part is absolutely loaded in bending, and of course it fatigues as it has to steer both ways. I've never really understood the merit of a single-ended rack with an overhanging clevis like this - apart from the ability to make the track rods really long and cut down significantly on bump steer I guess.
                            Glad it didn't end in tears!
                            __MDC__
                            Martin Cutting
                            • GT500
                              • Jun 2006
                              • 2181
                              I have changed two of these in the past, Not good.
                              Both had alot of miles 200.000 plus.
                              While your all checking your brackets have a good look at your left hand chassis leg, where it goes thinnest above the drive shaft, repaired cracked ones those too!!!
                              Rob..
                              87 UR 20v ABY
                              97 S6 Avant
