which springs front and rear
  • arranstone
    • May 2011
    • 447
    Installing Bilstein b6's in my coupe.
    I cant remember which springs go where.
    Shorter wider are....
    Longer narrower are.....
    help please
    This gallery has 1 photos.
  • vr6peter
    • Dec 2003
    • 223
    • Country: Austria
    Think the bigger diameter is rear, smaller front.
    • arranstone
      • May 2011
      • 447
      Also, is there a correct way up the springs sit?
      • arranstone
        • May 2011
        • 447
        Anyone else? Surely someone can give a definite answer to my original post.
        Is it taller springs at front and shorter at the rear?
          • Dec 2017
          • 5984
          If the part numbers are still visible you should be able to find out from that. On my Avant the rear springs are much smaller and tighter. To establish which way up, locate the top cap until it rests on the spring stop and it should be a snug fit. You could try a test fit in a strut. If you have the wrong one it will be very tight or too loose.
          sorry I can't be more help but I've not done a Coupe (yet)
          • arranstone
            • May 2011
            • 447
            I had all the components shot blasted so have no visible part numbers. I have tried test fitting with a top cap/cup but neither looked or felt correct. Gonna spend all day 2mrw at it.
              • Dec 2017
              • 5984
              There must be a pic on here. Might take a while searching it out.
                • Dec 2017
                • 5984
                This any help?
                • arranstone
                  • May 2011
                  • 447
                  Tractor Dave Your a star, thats what just i needed.
                  Fronts are longer/narrower
                  Rears are shorter/wider
                  • vr6peter
                    • Dec 2003
                    • 223
                    • Country: Austria
                    As said.
                    Bigger diameter (14,8) rear, smaller (14mm) front.
