ID part
  • ID part
    Hi I need to change some parts.
    B017525400A.. in etka it does not say it fits ABY , and it does not possible to buy.
    But there is nothing else to choose on.
    Same with B016409399B ,
    Does these fit on audi s2 avant - 93 ..ABY ?
    Best regards
    What is the part? I googled the first number and got nothing.
    Nothelle S2 Avant in restoration
    Wr Ur Quattro (also in restoration)
      2021-02-15_115819.jpg Its number 23 and 24 .. i got some oil leak , want to change it
            These 2 leaks , one on each side.
            But cant find what i should buy and what fits on aby .. s2 avant 93
              I think the part numbers are correct except for the B at start ?
              The smaller seal you should be able to buy quite easily, it's size is 45x60x8mm and is single lip type, the larger seal requires a tool to ease it into place.
              45x60x8mm R21 Single Lip Oil Seal | eBay
                I think 034 Motorsport do the larger seal. Expensive mind
                  Hi John ,, is there some how possible to find what kind of tool is needed for the job ?
                    017 525 400 A - there is a Corteco version available, part number 01020537B
                    Mike
                    http://www.s2-audi.co.uk
                      It'll look something like this... 3066/2, Seal Installer - Driver Set - Press Piece - Audi Authorized Tools and Equipment (snapon.com)
                        I believe these are the two you need Corteco parts 82017270 and 82020537
                        This gallery has 1 photos.
                          Here's the pic of the spare seal for my Coupe. I think it is different to your Avant. Best to check again.
                            I think i got my ones from Pete at Quattro Corner a few years back. And the oil from Audi so i was happy i had the right stuff. Maybe worth giving him a call.+44{0} 121 476 0034. One side was an Offensive price the other wasn`t too bad from memory. Hope this helps you fella
                            • #15
                              Found it on autodoc. Same brand
