Subframe nuts!
  • Bowie69
    • Nov 2013
    • 2675
    Subframe nuts!
    Hi all,
    I have one of the captive nuts going a bit 'soft' on my on the front subframe, hardly ideal, but there we are. Looking to replace it, but seem to be completely unable to find a supplier.
    My car is M10, and the found part number (from this forum) is 893803171. (M12 version is 8A0803171C).
    So... any ideas where they can be found, anyone?
    Current plan is to get a lump of steel, cut to size and drill/tap it, but I am sure it is much easier to just buy one
    Also, idle thinking, I guess as you can replace the nuts, you could 'upgrade' an M10 car to M12? Anyone done it?
    Thanks!
    • Dec 2017
    • 5983
    I think I have a couple of good ones. I will check what thread they are
      • Dec 2017
      • 5983
      I've had a quick look and so far they are M12
      I see Tradition have them if you have a friend in Germany.
      I will have another look after dinner for you.
      • Bowie69
        • Nov 2013
        • 2675
        Dave, top man, thanks, amazed anyone has anything like that kicking about, presumed most went to the skip with the shell.
          • Dec 2017
          • 5983
          I saved a couple but they all seem to be m12
          • Bowie69
            • Nov 2013
            • 2675
            OK thanks Dave, yeah traditional are a pain at the moment!
            • steve briance
              • Aug 2014
              • 1455
              Do you mean the nuts hidden inside the chassis? I've been fortunate enough not to need to replace any of my subframe nuts so have no idea what they look like but, maybe search for m10 captive nut or flat nut and see what google says?
              • SteveH
                • 4460
                Don't you have to cut into the rail to get at these?
                91 Modded 3B
                14 A6 Avant Black Edition
                • Bowie69
                  • Nov 2013
                  • 2675
                  Yeah, Tradition has them, and a pic:
                  However, no idea what size they are across the flats, or indeed the thickness (which looks surprisingly thin) -dimensions may be something you can help with, Dave? I'm assuming nothing changed in the chassis between M10 and M12!
                  Be quite happy to make some, in fact have some 40x12mm bar coming in case!
                    • Dec 2017
                    • 5983
                    M12 are 40mm x 25mm and about 8mm thick
                    And look the same as above.
                    • Bowie69
                      • Nov 2013
                      • 2675
                      Apparently not, there are rubber access plugs in the wheel well, pull them out and have a rummage.
                      This is the closest I can get as far as an image goes, though this is a B2 chassis (I think) here are a couple of plugs circles in green:
                      The B3 plugs are bigger, and I think a little lower down the chassis leg.
                        • Dec 2017
                        • 5983
                        I think you find they are in a little cage. I have a b2 chassis leg here and the nut is captive in that. A folded over metal cage holds it loose in a slot. From memory, S2 is similar if not the same.
                        • Bowie69
                          • Nov 2013
                          • 2675
                          Excellent, thank you!!! That was especially quick....
                          • Bowie69
                            • Nov 2013
                            • 2675
                            Cool, well, what harm can I do
                              • Dec 2017
                              • 5983
                              The chassis leg is for sale. FNS if it all goes horribly wrong . New from Tradition. I didn't need it in the end.
