You can't access the captive nuts through those plugs unfortunately as they are way too high for a start.
You need to cut out a square panel into the chassis leg to expose the nut and pry open the cage to release it. It would be a nice little upgrade to accept the larger bolts but the work involved is too great in my opinion. Then again, if you have the workshop equipment and the desire then have at it.
