10.9 is good. The only bolt outside the engine which is higher grade that I'm aware of is the crank bolt on the bottom pulley. Zinc plate (yellow) will rust much quicker than the oe bolts. Where I've used these in the past I've sprayed them with Bilt Hamber clear wax.
Great, thanks. What coating is OEM bolts?
'93 Audi UrS4 Avant
'15 Audi A7 quattro 3.0 TDI
Most of the bolts have cleaned up and will be zinc painted and 're used. I do have a good collection of used Audi bolts I can dig into if necessary. Sometimes, vagbolts on eBay have oe bolts so worth checking with the part number and also the size from 7zap
