I have a seal kit for PS pumps for a ‘91 coupe. Is there a website with pictures that shows how to overhaul them?
‘91 7A power steering pump overhaul kit
Try this.... Courtesey of Greg Wood.
Just a note that the Rennbay kit for Porsche does *not* include the correct shaft seal. You'll need a different one if you decide on replacing the shaft seal. Many don't because it requires you to pull off the pulley flange which can be pressed on very hard.
This is the shaft seal size: Rotary Shaft Seal: 16 mm Inside Dia., 28 mm Outside Dia., 7 mm Wd, Nitrile Rubber
