Steel or Alloy wishbones
  • smudge72
    • Apr 2005
    • 53
    I have to order some new wishbone bushes for my 95 s2 avant for the mot.
    i want to get powerflex bushes as i have heard that they last longer, but i dont no what type of wishbones i have.
    i have phoned up audi but he says that he can't translate german so i'm @ a loss so
    could someone out there help me please
  • HPmuirt
    S2Forum April Fool
    • Apr 2005
    • 3014
    Funny, just had a chat with Martyn at VAGParts about this very subject.
    Martyn is of the opinion that the Cast Aluminium units are better, as they are stiffer and also since the bush is larger it should last longer.
    However, on the down side, they are £116 each, plus you must change the ball joints at the same time, which are another £35 each.
    On top of that, the cast wishbones are more likely to snap if you have a bump (i.e. hit a kerb hard) whereas the pressed steel versions would bend, allowing you to potentially limp slowly home.
    So which am I going for.....still dunno. I may stick with the pressed steel units and have them seam welded to increase their rigidity.
    Hope this helps....it just confuses me.
    Cheers n
    Si
    Subtle mods here and there
    2011 A5 3.0 TDi - Lava Grey
    • topsparky
      • Oct 2005
      • 2014
      do you mean pressed steel or cast ones
      1. SHORT SHIFT KIT
      2. PORSCHE CAYENNE CALIPERS
      3. H & R SPRINGS
      4. BILSTEIN SHOXS
      5. NEW BUSHES AND HP2 STRUTS
      8. fmic fitted
      • Flat on my back
        • Jan 2007
        • 2449
        Cast wishbones?
        I have a set going spare plus ball joints, taken off my 90 sport. They will need bushes as the rear 2 are gone.
        I'll put the part no.s on tonite.
        Interested?
        Carlos.
        • smudge72
          • Apr 2005
          • 53
          cheers for the replies but i need to know what type of wishbones i have on my s2 avant 95 they are the original ones (but i don't know what type) so just need bushes
          • topsparky
            • Oct 2005
            • 2014
            stick you head under the car and have a look
            you should be able to tell the difference
            1. SHORT SHIFT KIT
            3. H & R SPRINGS
            4. BILSTEIN SHOXS
            8. fmic fitted
            • smudge72
              • Apr 2005
              • 53
              ok i will look but what is the difference
                If the wishbones looks like a big V it's the forged / cast ones.
                See the example in this thread http://www.s2forum.com/forum/showthread.php?t=14363
                • topsparky
                  • Oct 2005
                  • 2014
                  the cast ones are of a one pieces construction
                  the pressed ones look like two pieces stuck together
                  if that helps
                  1. SHORT SHIFT KIT
                  3. H & R SPRINGS
                  4. BILSTEIN SHOXS
                  8. fmic fitted
                  • Skull
                    • 3506
                    • Country: Slovenia
                    take a pic man.
                    Audi Quattro WR
                    • smudge72
                      • Apr 2005
                      • 53
                      cheers for that Jamo spot on as usual
                      • smudge72
                        • Apr 2005
                        • 53
                        just been on powerflex site & they have:-
                        pff3-101 for steel
                        pff3.102 for alloy
                        i have the pressed stell ones not the cast ones so do i pick the steel?
                        Jamo please tell me many thanks
                        • HPmuirt
                          S2Forum April Fool
                          • Apr 2005
                          • 3014
                          The other easy way to tell the difference is that you always have pressed steel ones on the rear. So if the fronts match the rear they are pressed steel, if they look completely different then they are cast aluminium.
                          Cheers n
                          Si
                          • volcano rs
                            • Jun 2005
                            • 2265
                            pressed wishbones seam welded and powder coated waiting to go on the shorty with urethane bushes
                            • s2dude
                              • Nov 2005
                              • 1631
                              Looks very nice Jamil
