My automatic urs6 has red ATF fluid and I want to drain it and fill it with the green mineral fluid. Any ideas?
How to drain power steering fluid
I would drain at the brake bomb which is the lowest point. Turn the steering lock to lock when disconnected. You will need to re fill with green, bleed the system and drain again to try and get as much out as is possible. Make sure front wheels are off the ground when bleeding and draining.Nothelle S2 Avant
