RS2 hub and bearing distance shim
  • Kiku
    • Aug 2010
    • 497
    Does anyone have any data or knowledge about shims between RS2 hub and bearing so that the hub ET is correct.
    I cant find pn for this part!
    1990 2.2 20VT Audi Coupe Quattro
    *Hx35/k26, MaxxECU, Wagner EM/IC *RS2 Recaro *4pot-Brembo *3" turboback *Treser *Koni/H&R
    1990 Audi 200 20v Avant 2.2 20VT *7 Seater *Full electric gizmos
  • K Simmonds
    • Dec 2007
    • 7627
    Which hub are you referring to, front, rear or both?
    I've helped completely strip a crashed RS2 and wasn't aware of any shim's, I just assumed the 5 x 130 hubs were were unique to the car, that's what it looked like to me.
    Though I could be wrong on that as I've never removed an RS2 hub from it's bearing carrier or compared a compete RS2 hub/bearing carrier assembly to an S2 one
    Though I'm happy to be proved wrong, Dave has recently reassembled an RS2, perhaps he noticed something, there must be a thread on here somewhere documenting how Porsche altered the required offset.
    1990 B3 2.0 80 quattro.
    1992 C4 2.8 Avant quattro
    1994 MTM RS2.
    1998 B5 TDI quattro Sport.
    2000 B5 TQS.
    • Kiku
      • Aug 2010
      • 497
      Front.
      One of the shims is broken 1/3 is missing from the shim and wheel is out of balance(when you drive it wobbles and the brake disc does not run straight when you roll it) due to tensioned axle bolt - i hope this description makes sense.
      FYI:this is one of the first RS2 rolled out from the factory, with big reds.
        • Dec 2017
        • 5992
        Yes, there are shims on all four hubs. I can measure for you if you like. I can't see a part number or find it on etka and I'm unsure exactly where they go.
        • Kiku
          • Aug 2010
          • 497
          Very appreciated the measures of the shim would be! Thank you Dave.
          • K Simmonds
            • Dec 2007
            • 7627
            Well you learn something everyday, nice one Dave. I never noticed those shims as there's obviously a fair amount of dirt around there on a car that's 20+ years old.
            1994 MTM RS2.
            2000 B5 TQS.
            • rxl
              • 1913
              You ment these?
              Gesendet von meinem SM-S928B mit Tapatalk
              • Rikki Kitto
                • Feb 2010
                • 6276
                And if they are forgotten the bearings keep failing don't ask
                • Kiku
                  • Aug 2010
                  • 497
                  RXL - are those for sale? If so, i need 1pc
                  • rxl
                    • 1913
                    send me a private message.
                      • Dec 2017
                      • 5992
                      The chamfer is difficult to measure
                      • Kiku
                        • Aug 2010
                        • 497
                        I thank everyone who put their brains in to this and helpd out! Got everything sorted out thanks to rxl.
